Finding and replacing text
Command
Path
Find-Replace Text
Text
The Find-Replace Text command searches for and optionally replaces text strings within a Vectorworks file. It can search for and replace text strings within text objects, record fields, and worksheet cells.
Use this command to find a text item, replace it, search for more occurrences, or replace all occurrences. All settings are retained from one use to the next, including find and replace text strings.
To find-replace text:
Select the command.
The Find or Replace Text dialog box opens.
Parameter
Description
Action
Locates and, if selected, replaces a given text string with a new text string
Find Next
Finds the next occurrence of the text string
Replace Next
Replaces the next occurrence of the text string
Replace All Selected
Replaces all selected occurrences of the text string
Replace All
Replaces all occurrences of the text string
Look in
Searches for occurrences in the specified parts of the document
Text Objects
Searches in all text objects
Record Fields
Searches in all record fields, including Callout objects
Worksheets
Searches in all worksheets; is grayed if Replace All Selected is chosen, since there is no selection attribute for a worksheet
Find String
Enter text string to search for
Replace With
Enter replacement text string; grayed if Find Next is selected
Options
Specifies the depth of the search
Active Layer Only
Searches in the active layer only
All Layers
Searches on all layers within the document, regardless of visibility
Visible Layers Only
Searches in all currently visible layers
Case-sensitive
Searches for text that exactly matches the criteria, including capitalization
Enter the desired search and, if using, replace criteria.
Click Find/Replace.
